I just installed my new V4 mjlj to replace my damaged V3 mjlj. Had a friend put the kit together and used a 9V battery with my wife's windows 7 laptop to upload my first map. Worked just fine! I even figured out how to make windows 7 load new firmware ( but it turns out it was already loaded).
Anyway, my older windows xp laptop would not connect but I'll worry about that later.
My issue is that I start the car and connect my wifes laptop (yes, windows7). Once the car has been running for about a minute the configuration software freezes and shows a timeout message. If I disconnect and reconnect the usb/serial adapter it works again. If I do not start the car and just leave it KOEO the software works fine, you can flash new settings etc. Issue only happens when the engine is finally running. Using a usb/serial adapter that I used with the V3 unit and no issues. Also using the autosport labs serial/rj11 adapter and rj11 cable.
Other than this it runs like a champ again, thanks to Brent and Ryan!
Minor issue with timeout after connection
So only when the engine is running? Its likely due to interference in the usb-serial adapter fom the ignition coils or alternator. On reason to explain why its not happening on v3 is that the baud rate is higher with v3- 38000 vs 4800 baud. The higher speed may be more susceptible to noise.
Previous users with this problem have solved it by extending the usb-serial adapter further away from thr unit / car through the use of a extension cable. You might want to try that too.
