hi,
how do i go about putting a shift light onto my megajolt jnr?
i've read the guide on here, but can't understand it
thanks, jimmy
shift light megajolt jnr
Here's the section in the installation guide that talks about installing a shift light:
http://www.autosportlabs.net/MJLJ_V4_ve ... hift_Light
Let us know if you have any specific questions!
firstly, thanks for the replybrentp wrote:Here's the section in the installation guide that talks about installing a shift light:
Thats the guide i've been looking at...
i just can't get my head round, on how to wire just a single shift light up.
do i have to 'set' it via the megajolt software?
cheers, jimmy
ps i'm totally new to this megajolt/eletronic ignition lark!
ahh thats where i'm going wrong thenspandit wrote:From what I understand, you wire a single shift light up as follows:
1) connect one end to a 12V source
2) connect the other end to the dedicated shift light pin on the MJLJ connector
3) set the shift light RPM in the software and flash to the controller
done, 1) + 2)
Just need to set the shift light RPM.
Are there any guides for that?
ahh nice one, found it, just need to plug it in, and check what mine is. haven't got the lead or car with mespandit wrote:It's easy - on the ignition map page (the table of numbers) there are 3 tabs. Haven't got it in front of me but click one of them and there is a box clearly marked to set the shift light and limit RPMs
cheers pal, very helpful guys!
Jimmy
