no spark
no spark
hi guys, i'm new here and am having trouble getting spark from my edis. i have a new coil pack,new vr sensor and new edis, i;ve traced all wires atleast 10 times. checked voltages and everything seems fine. cn you tell me how to adjust the vr gap on a stock zetec 2 litre? i'm trying to start without the mjlj thanks it seems i'm not alone with the problem of no spark. my engine is a zetec 2 litre from a 2000 zx2 escort with zx6r carbs and a miata 5 speed, i've got this in a morris minor and am hoping to get it on the road next month. as for the gap on the vr i get about 50 thousands on my verniers. is there some way to adjust this? thanks again
ok,i believe i can breath again.i changed the sheilded wire from the vr and nothing. then i checked the voltage while cranking over the engine and my voltage was around 8.4v so i ran battery voltage directly to the edis and coil and i had spark...backfiring and sputtering.reverse the coil wires and it runs. thank you for your help
