VR/Crank sensor positioning
stappinuk
Post by stappinuk »
I have a problem where I need to mount the sensor at tdc but the anti roll bar will clatter it once the car is dropped (arrrgghh!)
So I have two questions:
1: are there any shorter sensors I could use as mines too long?
2: can the sensor be mounted side on to the trigger wheel to detect the gap?
Cheers
Simon
Swedge
Post by Swedge »
Im sure the Mazda sensor I smaller not sure what car it's from though
The sensor can be mounted begin the pulley so it goes through the gaps if you know what I mean
stappinuk
Post by stappinuk »
Swedge wrote:Im sure the Mazda sensor I smaller not sure what car it's from though
Did you mean behind? Am I right in saying the sensor has to be mounted at TDC?
toenee
Post by toenee »
The later Zetec sensors are shorter, mines out of a late Ford Fiesta.
