Have installed MJLJ in basic mode ie Ford Edis and MJLJ with simple +ve, -ve, pip and saw connections.
Now, the edis must be working as the timing is rock steady at 10 btdc with the MJLJ disconnected.
However, when i plug the MJLJ in, i don't get anything showing on the rpm dial in tbe configurator setup; i get manifold pressure but nothing else?
The VR must be working for the edis to control the advance but why don't i get any rpm's showing and no ign control from the MJLJ?
I can 'get' the default map shown in the unit and write to it to, but why no control over the advance or rpm figures??
Co-incidentally, could this tie in with the fact that my cars rev counter also doesn't work when in MJ mde but dies in conventional?
Any help is much appreciated!
