Log voltage off of Pin2?
sbarton
Post by sbarton »
Is it possible to have the system log voltage and just use pin2, since that is hooked up to the power source anyway?
-Scott
Duct Tape Motorsports
MyTrackSchedule.com - Your key to more track events!
Hi Scott,
Analog channel #8 is internal and not connected to the terminal block and is hard-connected to measure system battery voltage, if I understand what you're referring to.
Just set a sample rate and select the channel name "Battery" and you're good to go.
sbarton
Post by sbarton »
Do I need to hook a wire to analog 8 to do that?
Nope! As before, it's internally wired and not hooked up to the terminal block. You get it automatically.
