Izze Racing Brake Temperature Sensors
gizmodo
Post by gizmodo »
I ordered four of these today (http://www.izzeracing.com/products/brak ... nsors.html). Does anyone else have these working with their RCP? If so, how did the integration with the RCP go?
We have customers using these already, and one of our dealers (RaceElectronic) provided CAN mapping information for the sensors.
https://wiki.autosportlabs.com/Izze_Rac ... re_Sensors
Keep us posted with how it works!
gizmodo
Post by gizmodo »
Cool, thanks!
One other thing. What would be the best way to connect the four sensors to the RJ45 plug? The simplest would be to solder them, but I'd like something a bit cleaner.
Not having seen how the sensor's wire terminations look, it might be a case where you take an RJ45 network cable and snip one end off, and splice the wires together.
Keep us posted on the progress!
gizmodo
Post by gizmodo »
It is just four wires coming off each sensor. Since I have four I'll just tie them together and connect them to a short piece of wire. The sensors need 5 volts, but require 30 mA so I'm guessing I can't use the 5 volt from the RCP, correct?
Your MK2 can supply up to 1A from the vRef. plenty of power for the sensors.
gizmodo
Post by gizmodo »
I had a chance to get these working today. There is one problem though. My sensors are setup for 16 channels each. I had to trim the script in the link above quite a bit because I was getting an out of memory error from lua. Even with trimming I was only able to get the front two sensors working. I can setup the sensors to use 8 channels but then I won't be able to do anything else with lua. Is there something I am missing here? I'd hate to think I can't use the ShiftX and Zeitronix scripts I have too. Here is the script I have working.
--This example is configured for IzzeRacing CAN-bus TireTemp-Sensors
--by www.race-electronic.com
setTickRate(30)
BDF1Id = addChannel("BDF1", 10, 0, -20, 950, 'degC')
BDF2Id = addChannel("BDF2", 10, 0, -20, 950, 'degC')
BDF3Id = addChannel("BDF3", 10, 0, -20, 950, 'degC')
BDF4Id = addChannel("BDF4", 10, 0, -20, 950, 'degC')
BDF5Id = addChannel("BDF5", 10, 0, -20, 950, 'degC')
BDF6Id = addChannel("BDF6", 10, 0, -20, 950, 'degC')
BDF7Id = addChannel("BDF7", 10, 0, -20, 950, 'degC')
BDF8Id = addChannel("BDF8", 10, 0, -20, 950, 'degC')
BDF9Id = addChannel("BDF9", 10, 0, -20, 950, 'degC')
BDF10Id = addChannel("BDF10", 10, 0, -20, 950, 'degC')
BDF11Id = addChannel("BDF11", 10, 0, -20, 950, 'degC')
BDF12Id = addChannel("BDF12", 10, 0, -20, 950, 'degC')
BDF13Id = addChannel("BDF13", 10, 0, -20, 950, 'degC')
BDF14Id = addChannel("BDF14", 10, 0, -20, 950, 'degC')
BDF15Id = addChannel("BDF15", 10, 0, -20, 950, 'degC')
BDF16Id = addChannel("BDF16", 10, 0, -20, 950, 'degC')
BPF1Id = addChannel("BPF1", 10, 0, -20, 950, 'degC')
BPF2Id = addChannel("BPF2", 10, 0, -20, 950, 'degC')
BPF3Id = addChannel("BPF3", 10, 0, -20, 950, 'degC')
BPF4Id = addChannel("BPF4", 10, 0, -20, 950, 'degC')
BPF5Id = addChannel("BPF5", 10, 0, -20, 950, 'degC')
BPF6Id = addChannel("BPF6", 10, 0, -20, 950, 'degC')
BPF7Id = addChannel("BPF7", 10, 0, -20, 950, 'degC')
BPF8Id = addChannel("BPF8", 10, 0, -20, 950, 'degC')
BPF9Id = addChannel("BPF9", 10, 0, -20, 950, 'degC')
BPF10Id = addChannel("BPF10", 10, 0, -20, 950, 'degC')
BPF11Id = addChannel("BPF11", 10, 0, -20, 950, 'degC')
BPF12Id = addChannel("BPF12", 10, 0, -20, 950, 'degC')
BPF13Id = addChannel("BPF13", 10, 0, -20, 950, 'degC')
BPF14Id = addChannel("BPF14", 10, 0, -20, 950, 'degC')
BPF15Id = addChannel("BPF15", 10, 0, -20, 950, 'degC')
BPF16Id = addChannel("BPF16", 10, 0, -20, 950, 'degC')
CAN_map = {
[1220] = function(data) map_chan(BDF1Id, data, 0, 2, 0.1, -100)
                        map_chan(BDF2Id, data, 2, 2, 0.1, -100)
                        map_chan(BDF3Id, data, 4, 2, 0.1, -100)
                        map_chan(BDF4Id, data, 6, 2, 0.1, -100) end,
[1221] = function(data) map_chan(BDF5Id, data, 0, 2, 0.1, -100)
                        map_chan(BDF6Id, data, 2, 2, 0.1, -100)
                        map_chan(BDF7Id, data, 4, 2, 0.1, -100)
                        map_chan(BDF8Id, data, 6, 2, 0.1, -100) end,
[1222] = function(data) map_chan(BDF9Id, data, 0, 2, 0.1, -100)
                        map_chan(BDF10Id, data, 2, 2, 0.1, -100)
                        map_chan(BDF11Id, data, 4, 2, 0.1, -100)
                        map_chan(BDF12Id, data, 6, 2, 0.1, -100) end,
[1223] = function(data) map_chan(BDF13Id, data, 0, 2, 0.1, -100)
                        map_chan(BDF14Id, data, 2, 2, 0.1, -100)
                        map_chan(BDF15Id, data, 4, 2, 0.1, -100)
                        map_chan(BDF16Id, data, 6, 2, 0.1, -100) end,
[1225] = function(data) map_chan(BPF1Id, data, 0, 2, 0.1, -100)
                        map_chan(BPF2Id, data, 2, 2, 0.1, -100)
                        map_chan(BPF3Id, data, 4, 2, 0.1, -100)
                        map_chan(BPF4Id, data, 6, 2, 0.1, -100) end,
[1226] = function(data) map_chan(BPF5Id, data, 0, 2, 0.1, -100)
                        map_chan(BPF6Id, data, 2, 2, 0.1, -100)
                        map_chan(BPF7Id, data, 4, 2, 0.1, -100)
                        map_chan(BPF8Id, data, 6, 2, 0.1, -100) end,
[1227] = function(data) map_chan(BPF9Id, data, 0, 2, 0.1, -100)
                        map_chan(BPF10Id, data, 2, 2, 0.1, -100)
                        map_chan(BPF11Id, data, 4, 2, 0.1, -100)
                        map_chan(BPF12Id, data, 6, 2, 0.1, -100) end,
[1228] = function(data) map_chan(BPF13Id, data, 0, 2, 0.1, -100)
                        map_chan(BPF14Id, data, 2, 2, 0.1, -100)
                        map_chan(BPF15Id, data, 4, 2, 0.1, -100)
                        map_chan(BPF16Id, data, 6, 2, 0.1, -100) end,
function onTick()
    processCAN(0)
end
function processCAN(chan)
    repeat
        if id ~= nil then
            local map = CAN_map[id]
            if map ~= nil then
                map(data)
            end
        end
    until id == nil
end
function map_chan_be(cid, data, offset, len, mult, add, filter)
    offset = offset + 1
    local value = 0
    while len > 0 do
        offset = offset + 1
        len = len - 1
    end
 local cv = (value * mult) + add
    setChannel(cid, cv)
end
map_chan = map_chan_be
initCAN(0, 1000000)
Great you got it to work!
But, first suggestion, I would just ditch the script and use the built-in CAN mapping capabilities available in the latest 2.11.0 firmware.
Seriously, it should work much better for you and save your Lua script for other custom integrations.
gizmodo
Post by gizmodo »
I was wondering about that. I'll give that a shot tonight or tomorrow. As always, thanks for the help!
gizmodo
Post by gizmodo »
I've had no luck getting this to work with the CAN Mapping. Regardless of what I put in for values I get a reading of 0. If I add the lua script back in I can see those values changing, so I must be missing something on the mapping setup. According to the documentation the transfer function is x/10-100.0 where x is the 16 bit channel. It also says Termination: None. Would this matter? I don't think so since it works in lua.
Here is the CAN section from my configuration:
    "canCfg": {
      "baud": [
        1000000,
        500000
      "en": 1
"canChanCfg": {
      "chans": [
          "add": -100.0,
          "bigEndian": true,
          "bm": false,
          "bus": 0,
          "div": 10.0,
          "filtId": 0,
          "id": 1220,
          "idMask": 0,
          "len": 2,
          "max": 950,
          "min": -20,
          "mult": 1.0,
          "nm": "DFBrake1",
          "offset": 0,
          "prec": 0,
          "sr": 10,
          "type": 0,
          "ut": "C"
          "add": -100.0,
          "bigEndian": true,
          "bm": false,
          "bus": 0,
          "div": 10.0,
          "filtId": 0,
          "id": 1225,
          "idMask": 0,
          "len": 2,
          "max": 950,
          "min": -20,
          "mult": 1.0,
          "nm": "PFBrake1",
          "offset": 0,
          "prec": 0,
          "sr": 10,
          "type": 0,
          "ut": "DegC"
      "en": 1
gizmodo
Post by gizmodo »
I made a bit more progress on this. After power cycling the RCP and restarting RaceCapture (I'm using the Windows version, 1.9) I was able to get readings using the setting above. However, when I tried to add more channels, either by editing the settings file and rewriting or adding channels through mapping I would only get value on the first two (in order of creation) CAN channels. For my event I went back to Lua scripting and only used 8 channels from each sensor and that seemed to work okay.
You should be able to use the UI for certain. However, we've received reports that the CAN mapping required a power cycle - which I haven't been able to reproduce yet.
If you can, try adding a few channels and power cycle after writing to RCP and see if that wakes it up.
If it still doesn't work, send me your config and I'll try to simulate the data on my end with a 2nd RCP (I don't have the same sensors as you)
gizmodo
Post by gizmodo »
I now have 32 CAN channels mapped. A simple power cycle of the RCP after adding the channels did the trick!
Great! Now we just need to catch it in the act and fix that bug :)
gizmodo
Post by gizmodo »
I seem to be able to reproduce it every time, so if there's a debug setting or something I can turn on let me know.
