I am trying to get IAT on my car so I can monitor the methanol injection IAT is on the obd2 channel but I've not found it int he canbus (2005 mini cooper S R53)
what's the best route to poll both at the same time? I'm already using both ports on the front of the racecapture one for bluetooth and one for wifi
I've also found how to pull brake pressure from the k-line bus, I've not looked into this yet I'm not sure if the canbus I'm tapping into is the same as the one the abs (MK60) is on
basically function call 21 06 and the pressure data is 21 02
the geniuses on m3forum posted this
The brake line pressures is present on the K-Bus by requesting the function call 21 06, and the brake line pressure offsets in 21 02. The formats are:
Status sensors (21 06):
Positive pressure:
B8 29 F1 02 21 06 45
B8 F1 29 0F 61 06 00 00 C3 DC 14 8F 14 A4 00 00 00 00 11 06
BrakeLinePressureFront = hex2dec('148F')/100 = 52.63 [bar]
BrakeLinePressureRear = hex2dec('14A4')/100 = 52.84 [bar]
BrakeLinePressureFront = hex2dec('1D31')/100 = 74.73 [bar]
BrakeLinePressureRear = hex2dec('1D1C')/100 = 74.52 [bar]
Neg. pressure by twos complement:
B8 F1 29 0F 61 06 00 00 C3 DC F7ED F783 00 00 00 00 11 06
BrakeLinePressureFront = (hex2dec('F7ED')-65536)/100 = -20.67 [bar]
BrakeLinePressureRear = (hex2dec('F783')-65536)/100 = -21.73 [bar]
BrakeLinePressureFront = (hex2dec('FFA5')-65536)/100 = -0.91 [bar]
Status sensor offset (21 02):
B8 29 F1 02 21 02 41
B8 F1 29 0C 61 02 FA89 FF18 1E81 FE5D 0000 A7
B8 F1 29 0C 61 02 xxxx yyyy 1E81 FE5D 0000 A7
xxxx = hex value in telegram of Offset Front
yyyy = hex value in telegram of Offset Rear
BrakeLinePressureFrontOffset = 0.000625*x + 2.3315e-15
BrakeLinePressureRearOffset = 0.000625*y + 2.3315e-15
where x is twos complement of xxxx (or yyyy) if neg value in xxxx (or yyyy) (msb set), otherwise pos value of xxxx (or yyyy).
Example: 0xFA89 => neg value since msb=1. Twos complement of 0xFA89 = -1399 => -0.87438 [bar].
Polling canbus for MK60 brake pressure, and odb2 for IAT
Jump to
- Autosport Labs
- ↳ General Discussion
- ↳ News and Announcements
- ↳ New Project Suggestions
- CAN Devices
- ↳ ShiftX2
- ↳ AnalogX
- RaceCapture App
- ↳ RaceCapture App Operation and General Q&A
- ↳ RaceCapture App Bug Reporting / Feature Requests
- CAN bus and OBDII integration
- ↳ CAN mapping discussion
- ↳ OBDII PIDs discussion
- RaceCapture/Pro | RaceCapture/Apex | PodiumConnect
- ↳ RaceCapture/Pro introductions
- ↳ RaceCapture/Pro General Q&A
- ↳ Sensors
- ↳ Hardware and Installation
- ↳ Lua Scripting
- ↳ Telemetry
- ↳ Bug Reporting
- ↳ Feature Requests
- RaceCapture/Track
- ↳ RaceCapture/Track Introductions
- ↳ RaceCapture/Track Operation
- ↳ RaceCapture/Track Installation
- ↳ RaceCapture/Track Bug Reporting / Feature Requests
- Megajolt/E and Megajolt Lite Jr. (MJLJ)
- ↳ Ignition Map Library
- ↳ Powered by Megajolt Gallery
- ↳ Assembly
- ↳ Installation
- ↳ Operation
- ↳ Q&A
- ↳ Future Upgrades
- ↳ Bug Reporting
- ↳ Fixes/Patches/Updates
- ↳ Hard Rev Limiter
