could not open comport
eds911915
Post by eds911915 »
hello MegaJolt_its bin awhile since iv bin to the autosport forum anyway iv got a Megajolt/e that i used to use in my 1974 2002 BMW i removed about 4 years ago and put it in a box it was working fine. so today i pulled it off the shelf and loaded all the firmware and drivers powered it up with a 9 volt battery set the comport but i cant connect getting a message "could not open port" im using the same USB R232 adapter that i used with my megasquirt controller i attached a screen shot to give you an idea what im talking about
Check device manager for what COM port your USB adapter is on, then change that setting in the Megajolt Software. It should connect after that.
Let us know if that works for you. Thanks!
