Heading via lua
Moderators: JeffC, stieg
MrBlahh
Heading via lua
Post by MrBlahh »
anyone worked out heading via lua?
not sure it's the best place to do it, due to jitter you would have to average out a few readings to calculate it reasonably
burn4005
Post by burn4005 »
came accross this post when looking to see if this bridge had been crossed..
I've created a function that will give heading angle in degrees.I haven't tested this yet but in theory it should work if Lua is fully implemented.
I got the function from:
https://www.igismap.com/formula-to-find ... longitude/
function headingcalc&#40;lat2,lon2,lat1,lon1&#41;
  rlat1 = math.rad&#40;lat1&#41;
  rlon1 = math.rad&#40;lon1&#41;
  rlat2 = math.rad&#40;lat2&#41;
  rlon2 = math.rad&#40;lon2&#41;
  dlon = rlon2-rlon1
  x = math.cos&#40;rlat2&#41; * math.sin&#40;dlon&#41;
  y = math.cos&#40;rlat1&#41; * math.sin &#40;rlat2&#41; - math.sin&#40;rlat1&#41; * math.cos&#40;rlat2&#41; * math.cos&#40;dlon&#41;
  rhead = math.atan2&#40;x,y&#41;
  return math.deg&#40;rhead&#41;
end
a lot of math functions to do, not sure how computationally expensive it will be. i'd operate it at a much lower tick rate than the GPS. maybe 10hz instead of 50?
thoraxe
Re: Heading via lua
Post by thoraxe »
MrBlahh wrote:anyone worked out heading via lua?
I'm curious why you wanted to implement this. I may have a similar need with integration with an AEM CD-7 dash.
