I'm currently sending a couple Analog inputs over and I wanted to send a virtual channel to SoloStorm.
1) How do I do that?
2) If I can't, is there a way to send a virtual channel to one of the unused Analog channels? Since I know how to send those that would work.
[Solved] Sending Virtual Channel to SoloStorm?
Re: Sending Virtual Channel to SoloStorm?
So if it's an Analog channel and you want the raw voltage you would choose one of the available auxillary channels in solostorm (no relation to the racecapture analog channel) and point it to the channel by using its mapped name. (Whatever you renamed the analog channel to or virtual channel)Canyonfive wrote:I'm currently sending a couple Analog inputs over and I wanted to send a virtual channel to SoloStorm.
Yes. Again you can choose any channel that you can see in your racecapture dashboard when selecting a gauge. Just pick an auxiliary channel in solostorm and type the name exactly as its mapped in the racecapture.Canyonfive wrote:2) If I can't, is there a way to send a virtual channel to one of the unused Analog channels? Since I know how to send those that would work.
