No rpm despite PIP signal is ok
Re: No rpm despite PIP signal is ok
Can you confirm that you can read the load value (TPS or MAP sensor) in the software and you can read/write configuration - but no RPM signal?
Note, PIP signal to Megajolt is 5v, not 12v. You may have a mis-wiring on the EDIS plug. Try to double check the wiring against our installation guide.
