Do you guys know if EDIS going to work with this type of trigger wheel: http://www.inet.hr/~artst/msavr/remenica1.jpg ...it is 36-1 custom made steel wheel.
EDIS with diferent trigger wheel
Got my finger on your trigger....
Hey Tonci,
The picture just may not be clear enough, but I don't see the missing notch. One notch has to be missing for the EDIS module to sync to #1 TDC. As for the style of notch, it will probably work, but they may not be quite large enough for the sensor to get a clear signal. You'll just have to try it.
Yes you did see it right. The
Yes you did see it right. The picture was taken before the one of the tooths was grind off.
Just to let you know, it does
Just to let you know, it does work...
