I have to modify my wheel and Pick up set up though. At present i have the wheel mounted on the front of the pulley and i want to machine the damper with teeth to make the whole setup simpler.
Does it matter what Width with the teeth are ? because the damper is somewhat larger than the Ford wheel i am using at present.
Does it matter that the damper is steel and not segmented iron?
Heres my set up as it is presently.
![Image](http://i5.photobucket.com/albums/y152/Mercmad/Mercedes%20Benz%20300%20SEL%2063/63cockups007.jpg)
