Ive taken 4 days to neatly run all the wires mount the trigger wheels, sensor brackets, EDIS etc etc etc.
i went to upload a map a friend gave me and MJ was having none of it
the megajolt is working! (it came with a map already loaded onto it for testing purposes) and it definately isnt on limp home mode.
trouble is i cant upload my map onto the megajolt... in fact i cant communicate with the Megajolt at all.... it crashes the configurator on the laptop...
i get no runtime readout, cant read maps from the unit, cant write to the unit, i cant do anything.
my laptop has no Serial connection, so i got a USB>Serial convertor. i made sure it was a supported one with the correct style drivers before i bought it (prollific?).
ive installed it correctly onto the laptop, found out its COM Port 5. opened up the config program, set it up to be COM 5. then as soon as i start the engine the config program gives me the following error:::
Runtime Error!
C://Program files/etc/MjConfig.exe
This application has requested the runtime to terminate it in an unusal way.
please contact the application support team for more information"
Ive no other computers at my disposal by the way...
I am at a loss, and need this sorted asap so i can drive it to the MOT ive got booked for Mid week. [/quote]
