New Install, RPM Challanges
Hi Rob, just to close out this thread, you were able to get RPM to work correctly? Thanks!
rob_h
Post by rob_h »
Yep, used pin #9 off the OBD2 connector. Samples at 10MHz.
We have a MK1 2.7.7 pre-release firmware that appears to have fixed the RPM problems at RCP power-up. You can download it here:
http://dropcanvas.com/bthz0/30
If the link above is bad, you'll likely be able to download the official release in the regular downloads area.
