If you are seeing erratic RPM then my bet is that your trigger wheel is not properly centered. Looking at your pictures it looks like your wheel is not mounted using a centralising hole so you will have a much harder time centering it. Measure your runout, my bet is that you have rather more than the 0.25mm that I would recommend.
I'm not terribly convinced by the sensor mount in your picture. It is hard to see what is going on in the photos but the use of a cable tie does not inspire me with confidence. For a sensor mount I always recommend 3mm steel or 6mm alloy in order to eliminate vibration which can confuse the sensor.
In terms of the crank sensor shielding the shield should be connected to ground at the EDIS module end only, it should not be connected to anything at the sensor end.
TESTING Megajolt
www.trigger-wheels.com
Alex:
I tested it like you said without megajolt and each spark plug is firing
They seemed feint the sparks but I'm doing it on a sunny day.
What do I do now please
EDIT: Connected megajolt and it all seems to be working now. I just re- earthed the vr sensor cable. I am sure it was but I made a stronger connection.
Rpm move up and down and spark plug fire evenly and all the time.
I need to do a video of the megajolt software and put it on here to show the rpm.
Also the trigger wheel is aligned perfect centre and the gap between the wheel and trigger is just approx 1mm.
The rpm move okay up to 2500 rpm in my drive test then get all funny after that. The everything started getting erratic again.
This is video of the trigger wheel moving.
Also picture of the gap. It's abut 1mm-1.5mm
I have a feeling it might be too far. Not sure.
https://www.youtube.com/watch?v=aTF6FAR ... e=youtu.be[/url]
- Zi6_1429.JPG (25.05 KiB) Viewed 10900 times
A smaller gap would be better, 0.75mm with a maximum runout of 0.25mm is a good target.
Well I bought another vr sensor connector. Re-wired it as the previous connector turned out to be loose and this time I inserted the nylon square insert into the connector so it would not wobble.
I also at the same time made the VR sensor as close as possible to the trigger wheel .
RPM's did not lose sync in the 1 hour trial run.
I leathered it 6000-7000 rpm and it was smooth all the way through. I went over pot holes and bumps at 40-50mph and it did not lose sync.
Does megajolt keep a history of the rpm so you can view it after a run and see it on a 'line-graph'?
