Page 2 of 2
Posted: Wed May 03, 2017 2:50 am
by boggie1688
Glad it is working.
What does the final script look like?
Posted: Wed May 03, 2017 8:06 pm
by PopKorn78
Here it is, I changed it for the ligths part to try to have them blinking. I used another script that was on the forum. Right now, they are only solid, but at least the work and I have RPM on the tablet.
FREQ_HZ = 30
loop_time = 1000/ FREQ_HZ
MAX_BLINK_PERIOD = 1000
DUTY_CYCLE = 0.2
--testRPM = 2000
LL1 = 6600
L12 = 7000
L23 = 7500
UL3 = 8000
function ctMAX(ll,ul,RPM)
	factor = (ul - RPM) / (ul - ll)
	blink_period = factor * MAX_BLINK_PERIOD
	return blink_period / loop_time
end
function variblink(ll,ul,RPM,chan)
	if j <= DUTY_CYCLE * ctMAX&#40;ll,ul,RPM&#41; then
		setGpio&#40;chan,0&#41;
	else
		setGpio&#40;chan,10&#41;
	end
	if j < ctMAX&#40;ll,ul,RPM&#41; then
		j = j + 1
	else
		j = 0
	end
end
function setLight&#40;ll,ul,RPM,chan&#41;
	if RPM < ll then
	elseif RPM >= ul then
	else
	variblink&#40;ll,ul,RPM,chan&#41;
	end
end
--the CAN baud rate
CAN_baud = 250000
CAN_chan = 0
--virtual channels
--addChannel&#40; name, sampleRate, &#91;precision&#93;, &#91;min&#93;, &#91;max&#93;, &#91;units&#93; &#41;
rpmId = addChannel&#40;"RPM", 50, 0, 0, 8000, "RPM"&#41;
vltId = addChannel&#40;"EcuVolts", 10, 1, 0, 20, "volts"&#41;
gearid = addChannel&#40;"Gear", 25, 0, 0, 6&#41;
iatId = addChannel&#40;"IAT", 1, 0, 0, 120, "F"&#41;
ectId = addChannel&#40;"EngineTemp", 1, 0, 80, 250, "F"&#41;
tpsId = addChannel&#40;"TPS", 10, 0, 0, 100, "%"&#41;
mapId = addChannel&#40;"MAP", 10, 2, -15, 25, "PSI"&#41;
injId = addChannel&#40;"InjectorPW", 10, 3, 0, 100, "ms"&#41;
ignId = addChannel&#40;"Ignition", 10, 0, -20, 20, "D"&#41;
knkId = addChannel&#40;"Knock", 1, 0, 0, 15, "count"&#41;
camId = addChannel&#40;"CamTiming", 10, 0, -20, 20, "D"&#41;
fuel2Id = addChannel&#40;"FuelLevel", 10, 0, 0,100,"%"&#41;
function toF&#40;value&#41;
 return value * 1.8 + 32
end
function setRpm&#40;value&#41;
RPM = value
setLight&#40;LL1,L12,RPM,1&#41;
setLight&#40;L12,L23,RPM,0&#41;
setLight&#40;L23,UL3,RPM,2&#41;
return value
end
--offset/length in bytes?
--format is&#58; &#91;CAN Id&#93; = function&#40;data&#41; map_chan&#40;<channel id>, data, <CAN offset>, <CAN length>, <multiplier>, <adder>&#41;
CAN_map = &#123;
&#91;1632&#93; = function&#40;data&#41; map_chan&#40;rpmId, data, 0, 2, 1, 0, setRpm&#41; map_chan&#40;vltId, data, 5, 1, 0.1, 0&#41; map_chan&#40;gearid, data, 0, 1, 1, 0&#41; end,
&#91;1633&#93; = function&#40;data&#41; map_chan&#40;iatId, data, 0, 2, 1, 0, toF&#41; map_chan&#40;ectId, data, 2, 2, 1, 0, toF&#41; end,
&#91;1634&#93; = function&#40;data&#41; map_chan&#40;tpsId, data, 0, 2, 1, 0&#41; map_chan&#40;mapId, data, 2, 2, 0.0145037738, -14.7&#41; end,
&#91;1635&#93; = function&#40;data&#41; map_chan&#40;injId, data, 0, 2, 0.001, 0&#41; map_chan&#40;ignId, data, 2, 2, 1, 0&#41; end,
&#91;1637&#93; = function&#40;data&#41; map_chan&#40;knkId, data, 0, 2, 1, 0&#41; end,
&#91;1638&#93; = function&#40;data&#41; map_chan&#40;camId, data, 2, 2, 1, 0&#41; end
&#125;
setTickRate&#40;FREQ_HZ&#41;
j = 0
function onTick&#40;&#41;
--RPM=testRPM
processCAN&#40;CAN_chan&#41;
--setLight&#40;LL1,L12,RPM,1&#41;
--setLight&#40;L12,L23,RPM,0&#41;
--setLight&#40;L23,UL3,RPM,2&#41;
end
function processCAN&#40;chan&#41;
    repeat
        local id, e, data = rxCAN&#40;chan&#41;
        if id ~= nil then
            local map = CAN_map&#91;id&#93;
            if map ~= nil then
                map&#40;data&#41;
            end
        end
    until id == nil
end
function map_chan&#40;cid, data, offset, len, mult, add, filter&#41;
    offset = offset + 1
    local value = 0
    while len > 0 do
        value = &#40;value * 256&#41; + data&#91;offset&#93;
        offset = offset + 1
        len = len - 1
    end
 local cv = value * mult + add
 if filter ~= nil then cv = filter&#40;cv&#41; end
    setChannel&#40;cid, cv&#41;
end
initCAN&#40;CAN_chan, CAN_baud&#41;
Posted: Fri May 05, 2017 2:20 am
Hey, glad you got it working. You know, you can take your script to the next level by moving the CAN mappings to the new direct CAN mapping scheme:
https://www.autosportlabs.com/racecaptu ... -released/
For now you'll need to pluck RPM via lua scripting, but you can move all of your other channels to the direct CAN mapping capabilities, which will lighten up your script and improve responsiveness.
For the blinking, I'm looking at this function:
function setLight(ll,ul,RPM,chan)
if RPM < ll then
setGpio(chan,0)
setGpio(chan,10)
else
end
I'm a bit unsure of the conditions that would actually cause variblink() to be called. Do you have a link to the original blinking shift light script you found that ostensibly worked?
You could try to put a debug print statement righ before the variblink() line to see if it ever gets called:
if RPM < ll then
setGpio(chan,0)
setGpio(chan,10)
else
println("variblink!")
end
and then watch the RCP log for those messages.
Posted: Fri May 05, 2017 10:59 am
by PopKorn78
Hi Brent, I used the script from GTSpirit. I'm using it for a base to improve that what I really want.
In the end, what I want is to have the lights to be solid while the RPM rises and the all lights to start blinking when RPM gets to 500 of the upper limit.
IE:
LL1: 6200 (Solid Green)
LL2: 6700 (Solid Green and Yellow)
LL3: 7200 (Solid Green, Yellow and Red)
LL4: 7500 (Blinking Green, Yellow and Red)
After that, I will be looking to have the Green and Yellow lights to blink individually as warning lights for Oil Pressur and Engine Temp, but that will be for later.
--virtual channels
SpeedGPS = addChannel&#40;"SpeedGPS", 25, 2, 0, 200, "KPH"&#41;
SpeedWhl = addChannel&#40;"SpeedWhl", 25, 2, 0, 200, "KPH"&#41;
-- CONSTANTS --
FREQ_HZ = 25  --1000/FREQ_HZ=loop time in ms. e.g. 25Hz=40ms--
loop_time = 1000 / FREQ_HZ
MAX_BLINK_PERIOD = 1200 --in ms &#40;1000ms to 1500ms suggested&#41;--
DUTY_CYCLE = 0.5
--testRPM = 5200  --test interface--
LL1 = 5000 --lower limit to start blinking light 1--
L12 = 6000 --sets light 1 on, starts blinking light 2--
L23 = 6500 --sets light 2 on, starts blinking light 3--
UL3 = 7000 --light 3 upper limit above which goes solid--
-- FUNCTIONS --
function ctMAX&#40;ll,ul,rpm&#41;
   factor = &#40;ul - rpm&#41; / &#40;ul - ll&#41;
end
function variblink&#40;ll,ul,rpm,chan&#41;
   if j <= DUTY_CYCLE * ctMAX&#40;ll,ul,rpm&#41; then
      setAnalogOut&#40;chan,10&#41;
   else
      setAnalogOut&#40;chan,0&#41;
   end
   if j < ctMAX&#40;ll,ul,rpm&#41; then
      j = j + 1
   else
      j = 0
   end
end
function setLight&#40;ll,ul,rpm,chan&#41;
   if rpm < ll then
    elseif rpm >= ul then
   else
   end
end
-- Ini --
j = 0
-- RUN --
setChannel&#40;SpeedGPS, getGpsSpeed&#40;&#41;*1.61&#41;
setChannel&#40;SpeedWhl, getTimerFreq&#40;1&#41;*0.92&#41;
RPM=getTimerRpm&#40;0&#41;
--RPM=testRPM
setLight&#40;LL1,L12,RPM,0&#41;
setLight&#40;L12,L23,RPM,1&#41;
end
Posted: Fri May 05, 2017 4:01 pm
Got it. Does using this original script at least blink your LEDs as designed? That would be the first base-line test I would recommend.
Unfortunately at the moment I'm not set up to precisely emulate the environment, so it's hard for me to test it.
Posted: Fri May 05, 2017 9:04 pm
by PopKorn78
No, blinking is not working. I will use the solid for now, by I will work on the blink and come back with results.
Posted: Fri May 05, 2017 9:53 pm
Got it. You might want to ping the original author of the script to see if there's an updated one that fixes any bugs, maybe he has something quick for you!
