Firmware was updated to 2.15, I think. It was the beta version posted.
App is 1.12.1 on iPhone,
Windows version should also be the latest available for download. I pulled direct from autosportlab site in early December (2018).
New to RCP\Datalogging but having a hard time connecting
Thanks.
Could you try exactly the following:
* Remove all OBDII channels
* Write settings back to RCP
* Load the "essential OBDII preset"
* change all channels to 29 bit
* Verify if OBDII works correctly (or not)
If it does not work correctly, could you then read back the settings from your RCP, then save to a new file, zip and attach here? We will run it against our OBDII simulator in 29 bit mode to see if we can catch any issues.
Brent,
I ran through the steps you listed. Unfortunately RCP still didn't pick up the data.
The config. (attached) still shows same, wrong 417001744, id.
Responses in CAN logging are seen on ids 417001745 and 417001757 (both seem to respond with the data). I tried to attach the logs I captured showing these responses (from an earlier attempt) but even zipped it exceeded the allowed file size.
- OBD2Only29bit1-9-19.zip
- (1.72 KiB) Downloaded 732 times
Re: New to RCP\Datalogging but having a hard time connecting
Old thread - we ran into this with a 2011 C8 corvette. We'll be updating the 2.18.8 firmware with support to look at 0x18DAF111 when in 11/29 bit automatic mode.
