Here is a more complete mapping of AEM Infinity items that can be mapped through the AEMNet CAN bus. Steering angle is probably in there as well, but I am not using that on my E36:
Here is the horrible looking text:
Signal Signal Byte Offest Length Scaling
AEMNet/A Engine RPM 32,546,816 0 2 0.39063 + 0
AEMNet/A Throttle Pos 32,546,816 4 2 0.0015259 + 0
AEMNet/A IAT © 32,546,816 6 1 1 + 0
AEMNet/A Coolant Temp © 32,546,816 7 1 1 + 0
AEMNet/A ADCR11 32,546,817 0 2 0.00007782 V/bit
AEMNet/A ADCR13 32,546,817 2 2 0.00007782 V/bit
AEMNet/A ADCR14 32,546,817 4 2 0.00007782 V/bit
AEMNet/A ADCR17 32,546,817 6 2 0.00007782 V/bit
AEMNet/A ADCR18 32,546,818 0 2 0.00007782 V/bit
AEMNet/A ADCR15 32,546,818 2 2 0.00007782 V/bit
AEMNet/A ADCR16 32,546,818 4 2 0.00007782 V/bit
AEMNet/A ADCR08 32,546,818 6 2 0.00007782 V/bit
AEMNet/A Lambda #1 32,546,819 0 1 "0.00390625
Lambda/bit + 0.5"
AEMNet/A Lambda #2 32,546,819 1 1 "0.00390625
Lambda/bit + 0.5"
AEMNet/A IGN Timing 32,546,819 5 1 0.35156 Deg/bit - 17
AEMNet/A Battery (V) 32,546,819 6 2 0.0002455 V/bit
AEMNet/A MAP 32,546,820 0 2 0.1 kPa/bit
AEMNet/A VE 32,546,820 2 1 1 %/bit
AEMNet/A Fuel Pressure 32,546,820 3 1 0.580151 PSIg/bit
AEMNet/A Oil Pressure 32,546,820 4 1 0.580151 PSIg/bit
AEMNet/A Fuel Pump 32,546,820 6.0 1 Boolean
AEMNet/A Fan 1 32,546,820 6.1 1 Boolean
AEMNet/A Fan 2 32,546,820 6.2 1 Boolean
AEMNet/A Brake Switch 32,546,821 7.0 1 Boolean
AEMNet/A Oil Temp © 32,546,823 6 1 1 Deg C/bit - 50
AEMNet/A Airbox Temp 32,546,820 5 1 1 Deg C/bit - 50
AEMNet/A Knock FB_Cyl1 32,546,848 0 1 - 0.1 degree/bit + 0
AEMNet/A Knock FB_Cyl2 32,546,848 1 1 - 0.1 degree/bit + 0
AEMNet/A Knock FB_Cyl3 32,546,848 2 1 - 0.1 degree/bit + 0
AEMNet/A Knock FB_Cyl4 32,546,848 3 1 - 0.1 degree/bit + 0
AEMNet/A Knock FB_Cyl5 32,546,848 4 1 - 0.1 degree/bit + 0
AEMNet/A Knock FB_Cyl6 32,546,848 5 1 - 0.1 degree/bit + 0
AEMNet/A DL Wheel Speed 32,546,833 0 2 0.02 kph/bit + 0
AEMNet/A DL Wheel Speed 32,546,833 2 2 0.02 kph/bit + 0
AEMNet/A DL Wheel Speed 32,546,833 4 2 0.02 kph/bit + 0
AEMNet/A DL Wheel Speed 32,546,833 6 2 0.02 kph/bit + 0
