Very newbie Qs
Posted: Fri Mar 09, 2007 11:53 pm
All,
Please forgive a electrical simpleton, confused.
I have searched the board for advice - please point me nicely if it is already there.
I have a ready made from Brent, MJLJ box with a wiring loom, EDIS-6 box, crank sensor, connectors etc. I'm fairly confident about the various connections to the car, setting up the crank sensor etc. but...
Testing - lots of refs to bench testing, but the advice rapidly descends into technotalk and oscillators. How can you bench test it without it being connected to the engine? Is testing just the MJLJ box, and a PC? Does a 9V battery go to the 12V connection? Do I need to do this if the Maestro made it?
Molex. The Build and Installation guide shows the Molex connections for an EDIS-4 and says that the -6 and -8 will have their own. What are they, please?
Revlimiter: The FAQ says that, "This Rev Limit output, like the other programmable outputs, is an 'open collector output', meaning it conducts 'ground' when enabled." What does this mean? I have a rev limiter that I think shorts the conventional coil when a limit is reached - it has two connections to the coil. Is this compatible with the MJLJ, and how? I'd like to keep it as I can change the rev limit without resorting to the PC and the config program (see below)
Shift light. My conventional revlimiter incoporates a shift light - it lights up when rev limitation is imminent. Does the shift light shown on the wiring diagram do the same?
12V supply. There is a capacitor shown in the 12V supply - is this included in the MJLJ box? What does a 25microfarad capacitor look like? I have a catalogue with 20 pages of capacitors - I can't find any rated for 12V, only 10 or 16V, nor at 25microfarads, only 22 and 33.
Java: I know what Java is but where/when do you use it with MJLJ? I have downloaded the MJLJ Configurator and it runs on my PC. Do I need a Java application?
Enough! Some kindly replies may clear my head, and will be received with much gratitude!
Thank you
John
Thank you
John
