Mega Jolt compatibality with Logworks
Posted: Sat Sep 15, 2007 10:12 pm
by merlin
Hi I have just baught the G3 A/F ratio gauge and LC-1 from Innovate Motorsports is there any compatability between the Mega jolt and the LC-1 for data loging.
Merlin
Posted: Sun Sep 16, 2007 5:39 pm
What things would you like to log?
The MJLJ doesn't have any dedicated logging outputs. However, depending on the logging hardware you have, certain things may be possible.
Ignition advance- If the logging system can measure pulse-widths, you extract the ignition advance by having it measure the SAW pulse.
MAP reading- you can probably modify the MJLJ board to bring out the MAP sensor voltage output to an unused pin on the connector; or, if you have TPS you could read the TPS sense line.
RPM - the logger should have this in-built.
Anything I missed?
Posted: Sun Sep 16, 2007 9:02 pm
by merlin
Thanks brent,
that is spot on RPM and MAP is realy all I want I think that LogWorks trough the LC-1 uses voltage as it trighers so not sure how to get RPM in trought this
wha mods do you recon i would need to make to the board to get a map voltage out.
Thanks for all your help.
