The ignition map grid
Posted: Mon Dec 10, 2007 10:59 pm
by luke6040
just a quick question, is ther a way to change the grid size of the ignition map, iv noticed alot of pictures show a 10 x 12 grid?
Thanks Luke
Posted: Tue Dec 11, 2007 4:15 am
Hello Luke,
The controller is fixed for a 10 x10 grid. Where are you seeing a 10x12?
Posted: Tue Dec 11, 2007 6:26 pm
by luke6040
ukminiturbo wrote:this is'nt a finished or perfect map but runs with no pinking or troubles, its for a NA engine but can be improved!
i found this 12 x 12 one its the 1 i need but the grids only show 10 x 10
Posted: Tue Dec 11, 2007 9:43 pm
by KLAS
12x12 sounds like MegaSquirt Extra
you may change it to 10x10 if you change the values
Posted: Wed Dec 12, 2007 8:07 am
by Gilesy998
That map is indeed a megasquirt map, belonging to a guy called wil_h and was posted on minifinity.com early last year. If you look on minifinty's technical library (link near the top of the boards) there's a MJLJ article, and within that is a link to the map database. In there is a 10x10-ified version I created by jiggling it around an removing feild where they weren't so badly needed.
Posted: Wed Dec 12, 2007 11:46 am
by luke6040
thats great thanks, im mostly just making sure i can do everything correctly befor i purcase one in jan, as im not an amazing machanic. so any tips would be great
