What's the firing order of the coils ?
Posted: Thu Jan 31, 2008 4:04 pm
by Patriq
Sorry, but I just can't figure out - what is the firing order of the coil package ?
When I have the firing order of my 4 cyl engine - which cyl goes to which coil ?
Maybe this should be in the FAQ ?
Posted: Thu Jan 31, 2008 4:55 pm
by david jenkins
The standard Ford coil has the cylinder numbers written next to the connectors. 1 and 4 fire together, then 2 and 3 I believe. On my Ford X-flow, cylinder 1 is at the front (fan end).
David
Posted: Thu Jan 31, 2008 5:05 pm
by Patriq
ok, thanks.
I'll check the coil pack again then. Couldn't see anything obvious last night. But then again - the garage where I'm working right now is rather dark.
Posted: Sat Feb 02, 2008 10:55 am
by Oliver Sedlacek
Four cylinder engines run either 1243 or 1342. A wasted spark ignition should be connected with one coil pair connected to 1 and 4, the other coil pair on 2 and 3. The outputs of each coil pair are interchangeable, so this works for either firing order.
