Alloy Triggers?
Posted: Mon Mar 10, 2008 3:34 pm
by Spitfire4
Hello,
I'm looking to get my crankshaft pulley remade in alloy and wondered if at the same time I had the 36-1 triggers fabricated as part of the pulley.
Can the triggers be made of alloy, or do they need to be made of steel?
Cheers
Craig
________
Vaaapp
Posted: Mon Mar 10, 2008 5:50 pm
by MartinM
Trigger wheels have to be of ferrous material ie normally steel - alloy, by itself, will not work at all.
One way that apparently works well is an alloy disc/pulley with cap head steel bolts every 10 degrees (with one missing of course) and then pointing the VR sensor at the cap heads.
Posted: Mon Mar 10, 2008 10:30 pm
by Spitfire4
Hi Martin,
Thanks for the info. As an alternative I'm thinking the rear of the alloy pulley could be machined to accept a ring gear style trigger wheel instead.
Cheers
Craig
________
Zx14 vs hayabusa
Posted: Tue Mar 11, 2008 12:18 am
by MartinM
Yep, that would work just fine....
