Wanted map connector
Posted: Thu Mar 20, 2008 2:46 pm
by gav
Hello i'm after the map connector that bolts to the case of the MJ unit, anyone have a spare or know where i can get one urgently? Cheers
Posted: Thu Mar 20, 2008 3:08 pm
by MartinM
Allegedly available in model aircraft hobby shops as they're used to get fuel from one side of a bulkhead to the other
...or in a real emergency, something like an M6 bolt, with the head cut off and a 3-4mm hole drilled through the middle, and two M6 nuts....
Posted: Thu Mar 20, 2008 4:36 pm
Posted: Mon Apr 07, 2008 10:01 am
by gav
Tried the mcmaster one, they wont sell to anyone outside the US, any others out there?
Posted: Mon Apr 07, 2008 3:55 pm
It seems your best bet is to use the hobby model aircraft bulkhead connector- see the link in the previous post.
Brent
Posted: Tue Apr 08, 2008 10:00 am
by gav
Tried that too $17 delivery charge to the UK
i cant believe they are this hard to find
Posted: Tue Apr 08, 2008 3:22 pm
What about a local hobby store? If you describe what you want they may be able to dig one up from their suppliers. That hobby bulkhead fitting is made by "fourmost".
Another thing you could do try is take a small bolt or stud and drill a hole through it. Use brass for ease of drilling.
Posted: Tue Apr 08, 2008 3:34 pm
by alexander
... or windscreen washer fitting, jammed through the/a hole and glued.
Posted: Tue Apr 08, 2008 7:07 pm
by gav
Cheers for the quick replies, sorry to be a pain am just a bit of a perfectionist and dont like to bodge anything lol. Think i might have to in this case though. Thanks
Posted: Tue Apr 08, 2008 7:15 pm
by gav
Result, MartinM from this forum has kindly sorted one out, if anyone does find a source for them in the UK please can you post here, thanks
