Just starting out, need a little help,
Posted: Wed Jun 04, 2008 8:29 pm
Hi everyone, i've installed megajolt on my vw type 1 1641cc engine, it's all running ok with the default map but i now want to start tuning with my own map,
firstly my trigger sensor is mounted so when the engine is at tdc the missing tooth is 90deg ahead, this appears to be the wrong way round according to the instructions, the engine still runs though, is this because the leads are also crossed over? i installed edis well over a year ago then built a new engine, but i do remember having to swap the leads around to get the old engine to run, will it affect the advance?
Also just a few basics for making a map, in general should i increase the advance as the rpm increases and decrease with load? or is it more linked to the amount of fuel required, hence as the engine leans out at higher rpm the advance decreases?
sorry for the stupid questions, i'm just trying to walk before i run!
