megajolt junior and coil on plugs.
Posted: Sat Jun 07, 2008 6:51 pm
by bad bug
Good day All,
Can mega jolt junior be used with coil on plugs from a nissan sylvia and also is megajolt junior affiliated with megasquirt.
Posted: Sat Jun 07, 2008 8:35 pm
Some have experimented with running separate coil-on-plug modules in series or parallel on each EDIS channel to get the same wasted-spark effect, but the consensus seems to be that the best and most reliable approach is to have the same coil pack arrangement the EDIS module was designed for.
Having said that, this is the closest and best approximation of coil-on-plug using an EDIS module:
http://www.autosportlabs.org/viewtopic.php?t=1308
Autosport Labs and Megajolt Lite Jr. are not affiliated with the Megasquirt project.
Posted: Sat Jun 07, 2008 9:29 pm
by bad bug
Thanks for the reply brent. My setup will be used on a 2.0ltr vw type 4 aircooled engine.
Posted: Sat Jun 07, 2008 10:58 pm
Great to hear. With IDF carbs or stock arrangement?
How's the weather in Jamacia?
Posted: Sun Jun 08, 2008 5:13 am
by bad bug
I will be using 44mm weber idf's i also bought a LM1 with LMA3 unit to do some tunning. The weather here is great, got some rain the other day to cool things down.
