API update?
Posted: Tue Aug 12, 2008 5:11 pm
by dave9469
Hi Brent
The API documentation says it's for 3.1.0/2.7.0. Is there a difference in 3.2.1 and is there an update to the documentation?
Will there be a firmware update for v3 coming soon which will require the API updating and are you waiting for that?
Cheers
Dave
Posted: Thu Aug 14, 2008 5:31 am
Hi Dave,
Actually, there's no API difference for 3.2.1 and 3.1- 3.1 was the beta for 3.2.1 and the API was already firmly cast by then.
V4 has an extended API- I still need to publish that! thanks for the ping; it's on the to-do list.
the next V3 firmware will have an extended API as well, it's TBD whether it will be exactly the same as the V4 API.
Posted: Thu Sep 18, 2008 11:20 pm
by Alexander_Monday
I am currently finishing up the hardware and writing the software to monitor 4 EGT, 4 CHT, 2 IAT, and whatever other 6 inputs I determine I want on an Ipaq.
I am having it display and also monitor the readings for low, high, and differential between cylinders.
I would love to incorporate the ignition. I would have to switch between com lines, as the old donor Ipaq I am using only has 1 serial com available.
I am new to Megasquirt, and I assume the firmware and PC software is not open source?
I found
http://www.autosportlabs.net/asl_dist/m ... cation.pdf which is for V3.
Have you published the extended API for V4?
Posted: Fri Sep 19, 2008 12:20 am
Hi Alexander,
I have this task and others on my to-do list. I'll push it to the top as it's an easy one to knock off; I should have the updates on the website by the weekend.
Thanks for the reminder!
Posted: Mon Sep 22, 2008 3:23 pm
