So far, so good...
Posted: Thu Oct 02, 2008 12:07 pm
by h4887
I've just got my 1380 A+ running successfully on the EDIS4, but with the timing at 8 deg instead of 10. Am I right in thinking V3 doesn't have the trigger offset facility (if so I can't find it!) so I will need to edit the whole map to compensate? It's noticeable how steady the timing is compared with the distributor which always has quite a bit of flicker at tickover. Now I just need to sort out that vacuum connection...
Posted: Fri Oct 03, 2008 3:39 am
That's correct- for now, V3 you have fixed base timing. That will change with the upcoming V3 firmware, where you can configure the offset in a similar way to V4. (see the "future upgrade" forums for news on when that will be available)
However, with only 2 degrees to compensate, you might be able to bend or slot the holes for your sensor. It might be worth considering!
Posted: Fri Oct 03, 2008 11:07 am
by TwoSheds
or not bother!
I think that the single most noticeable thing when I first put EDIS on mine was the stability of the timing. On my old V8 the advance at idle was bouncing around within a 15deg range
and the tickover was a rough as a badger's Rse
Now the advance is rock-solid and the tickover is smooo-o-o-oth
Thank you Brent for providing MEGAJOLT
Posted: Tue Oct 14, 2008 7:54 am
by G21
My Midas is now running nicely on MJ. However my initial joy on seeing the rev counter working soon evaporated when I realised it was lagging up to about 3000rpm after which it subsided to zero. That's using the MJ tach out connection. Has anyone managed to get a standard Metro rev counter working properly?
Posted: Thu Oct 16, 2008 11:35 am
by MartinM
Try driving the tacho from the PIP signal going from EDIS to MJLJ - this often solves exactly the problem you are seeing.
Just "T" into the existing EDIS->MJLJ wiring.....
Report back if it works!
Posted: Sat Oct 18, 2008 7:38 pm
by h4887
Thanks, Martin, I've got it running from the PIP signal now and it seems OK, at least it goes over 3000. Of course I don't know how accurate it was originally, probably not very...
Geoff a.k.a. G21
