Shield Cable - Can you use USB Cable?
Posted: Wed Nov 12, 2008 11:39 pm
by Dean924s
Has anyone used USB cable for the PIP and the SAW wires? It Is cheap, and is a shielded cable BUT the gauge of the wire is very thin. 25-30 ga????
I guess the real question is how much load is on these wires.
This also goes for the VR sensor. USB cable would be a great solution BUT again the gauge is so darn thin. I think the real problem may be the environment in the engine compartment.
Posted: Thu Nov 13, 2008 12:10 am
by DannyP
Dean, I used some nice heavy shielded stuff from an older Subaru(wrecking yard). They have many wires that need shielding, so easy to find. All I found are two conductor plus shield, exactly what we need. About 5/16" diameter, and looks like 18 or 20 gauge conductors inside.
Started and ran right out of the box, no interference or problems of any kind. The Suby wires are for cam, crank, and speed sensors, same as our requirements.
Posted: Thu Nov 13, 2008 7:39 am
by Dimbit
I used a 4-core burglar alarm cable for pip/saw and to the TPS. It was about the thinnest wire I've ever had to strip but works fine. We're not running huge currents here.
Posted: Thu Nov 13, 2008 6:54 pm
by Gilesy998
Sheilded/Screened microphone cable is dirt cheap, easy to get and easy to use.
Posted: Thu Nov 13, 2008 7:23 pm
Gilesy998 wrote:Sheilded/Screened microphone cable is dirt cheap, easy to get and easy to use.
Agreed. Radio Shack should have what you need.
Posted: Thu Nov 13, 2008 7:50 pm
by Midas
Glad to hear that, I've just raided Maplins
Posted: Fri Nov 14, 2008 3:08 pm
by nickj
I used shielded TP network cable. Thin gauge, so I paired the wires. Seems to work ok, but the car isn't on the road yet!
Nick
