running this setup on a 700 horse blown small block 350
Posted: Fri Dec 12, 2008 5:58 pm
I am really excited about all the features of this setup and would like to set it up on my 67 camaro with a blown small block, but I had a few questions
will the map sensor that uses load for calculating ignition advance work for a setup that has boost(positive pressure). naturally aspirated setups have vacuum that drops to 0 for maximum load conditions, but on mine I go positive so I was wondering if that would work.
Can I somehow run a knock sensor that would limit spark advance or take out timing if I get into detonation?
is there enough spark energy to full burn a mixture that has 20pounds of boost pressure and a total output of 700 horsepower?
Is it possible to setup a 2 step rev limiter (for an ex. a limiter of 7k rpm, and a limiter at 3k rpm wired to a switch)
I read that you can hook my wideband up to it, what does that allow me to tune with the ignition setup
thanks!
thanks!
