what am i doing wrong??
hi all im having trouble with getting my car started. wont even cough or splutter, ive run the battery down twice trying/checking different things. so......
fuel........yes
spark.....yes
mj power.....yes
edis power...yes
coil power....yes
as for my trigger wheel just need to clarify as ive read different things and looked at different things, my car is 4 cylinda and turns clockwise. so with the engine set at tdc should the nothced tooth of my trigger wheel sit level with the tdc marking and then the vr sensor be placed 90 deg defore that. or should the sensor and the notched tooth be sat 90deg befroe tdc? ive tried both. the drawing on the install pages sugests the first setup.
some body help its driving me nuts! it wont run on edis or mj. but everything is there to say it should? HELP!!
fuel........yes
spark.....yes
mj power.....yes
edis power...yes
coil power....yes
vw golf 2.0 16v zx9r carbs
ok double checked every thing and it was all spot on, turned the key and it started after pouring fuel into the carbs. problem now is it will start on its own fuel but dies afterabout 10 secs of steady idle. no matter if i touch the trottle or add/remove the choke? so i disconected the mj and it does exactly the same on edis? still cant get my tps to calibertae either.
i know the pump is fine as it was running before i did the mj conversion, unless its broken while doing the conversion. still primes when i flick the ignition on? i wondered whether it wont run because i haven't got the tps caliberated yet,would this cause it, but then again it does it on the edis only to. i'l make sure its not the fuel pump first. thanks
Ah, electrical pump. As brent has already questiond, Is the pump continuing to run when the engine fires? I strongly suspect not! Was it originally K-Jetronic? With the tachymetric relay looking for a coil -ve signal to keep the pump running? If so, that'll be your problem.You need to feed the pump with 12V some other way - my suggestion for another method is detailed here.
There is a previous topic discussing fuel pump relays- see here:
http://www.autosportlabs.org/viewtopic. ... ay&start=0
In short- You want enable the fuel pump while cranking and running, but deactivate it when the engine stalls. However, the MJLJ cannot measure below 450 RPMs, so detecting a stall condition with the MJLJ is not practical. This thread was discussing alternate techniques for achieving the desired effect.
Hope this helps,
Hope this helps,
In the two other threads linked from here, the emphasis was on safety. The goal was to disable the fuel pump if the engine stops running.
In an accident situation, a fuel line might be severed, or the vehicle might be upside down; a mechanical failure may occur (like an engine mount ripping away, causing hoses to pop off, etc.) a fuel pump will continue working without these safety measures.
Under these failure modes, the fuel pump you describe will continue to work, causing an obviously dangerous situation.
Hope this helps,
Hope this helps,
