No SAW or Tach
No SAW or Tach
So I'm converting from ESC (Ford stand alone ignition module) to EDIS4 + megajolt on my Zetec. Megajolt starts and gets connected to my PC and no issues with loading and reading files. Aux sensor works as well as the MAP sensor. PIP goes in and no SAW to the EDIS4. No TACH indication on the configurator. Coil signal is driving the external tach but is imaterial for this problem. Engine stars and runs, but the EDSI4 module is in limp home mode with spark fixed at 10 degrees. Harness has beeen double checked. Any ideas?
All,
I connected a signal generator to the PIP connection of the megajolt. 12v square wave at 50Hz. It goes onto the MAX232 chip but does not come out the otherside. I removed both the microcontroller and the line driver and now I have a signal coming out of the max232. I plugged the line driver back in and it still works and I have a output on the line driver. As soon as I plug the micro back in, it quits like the port on the micro is grounded.
Will this happen if the port on the micro is not configured for input?
dlh98370
dlh98370
Brent,
Version4 and it has not ever worked. What I mean when I say that is I can see the micro communicating with the PC. The MAP sensor reads correctly as well as the temp sensor, so its difficult to say the micro is bad. If I had another max232 laying about I would put it in and try that. I did remove the line driver an left the micro in to see if it was some kind of loading problem, but no luck there. Should I try flashing the firmware on the micro?
dlh98370
dlh98370
