got unit together,now i have some questions
Posted: Wed Nov 10, 2004 10:50 pm
by codydaniels
Now that i'm ready to install my mjlight I would like to ask a couple of questions.
1st- When I mount the edis module and coil,do they need to be grounded if I put them onto an aluminum mounting bracket?
2nd- How are you guys attaching the vr sensor to your motor?Home made brackets I would assume,but I would like to hear how someone else has done it.Thankyou in advance for any input.
grounds
Posted: Sat Nov 13, 2004 10:07 pm
by dermot
Answers;
1/
No, you don't need to seperately ground an EDIS coil or the EDIS module as such - just follow the wiring info which is around on the net if you look, or these pages. There is of course a ground point for the EDIS etc.
2/
Again, quite a few pictures around the net. In fact the sensors for all these sorts of systems are similar. I used sheet steel to bend up and shape a suitable bracket for my 30 year old Ford, for example.
br
D.
Thankyou just makeing sure I
Posted: Wed Nov 17, 2004 12:12 pm
by codydaniels
Thankyou just makeing sure I have it right
