MAP sensor doesn't work... What am I missing.
Posted: Thu Sep 30, 2010 5:27 am
by SleepingBlazer
I just got my setup running on my Chevy small block powered '84 s10 blazer.
The MAP sensor is hooked up but doesn't give a read out.
Its working like a mechanical advance dizzy at the moment.
I can't find any other MAP settings besides the one option in the configurator Options.
My vacuum seems abundant, there is plenty of hissing/whistling when I remove the hose.
Any suggestions????
Posted: Thu Sep 30, 2010 6:56 am
by NITROPIXIE
Did you make the board yourself?? If so did you put the MAP sensor on the correct way round??
Ryan
Posted: Thu Sep 30, 2010 12:44 pm
by SleepingBlazer
Nope. Its a pre-assembled one.
Posted: Thu Sep 30, 2010 1:20 pm
Hello,
Are you able to use the software to connect to the Megajolt and read / write ignition maps, and observe an RPM signal? Do you see any error messages in the bottom of the window like "timeout" or so on?
Posted: Thu Sep 30, 2010 1:29 pm
by SleepingBlazer
I will have to check for errors again, but I am pretty sure there are none.
RPM signal is good.
Software works like it should.
Truck runs better than ever, just no MAP.
Posted: Thu Sep 30, 2010 3:42 pm
Sorry if you've done this already- what if you watch the software and suck/blow into the map sensor port? you should be able to see the on-screen gauge move a bit, while the software is connected to the controller.
Posted: Thu Sep 30, 2010 6:33 pm
One more thing. When the Megajolt is powered up and connected to the software, but the engine isn't running- what is the KPa Value indicated in the config software?
Posted: Thu Sep 30, 2010 8:11 pm
by SleepingBlazer
Tried sucking and blowing on the tube to no avail already.
The KPa gauge reads 100 (wot) at all times.
Posted: Thu Sep 30, 2010 8:34 pm
Got it, thanks for checking. Can you follow up with us at
sales@autosportlabs.com and we can help you further.
