recieved my serial-usb converter from ebay today and this is what is it says in the drivers.txt
PL-2303 Driver Setup Installer, Prolific Edition
Setup Installer Revision Note History
System Requirement:
. Supports the following Windows OSes:
- Windows 98SE
- Windows ME
- Windows 2000 SP4
- Windows XP SP2 and above (32 & 64 bit)
- Windows Server 2003 (32 & 64 bit)
- Windows Server 2008 / 2008 R2 (32 & 64 bit)
- Windows Vista (32 & 64 bit)
- Windows 7 (32 & 64 bit)
NOTE: For Windows 7, please use RC build 7100 or above.
. USB host controller
. Device using PL-2303H/HX/X version chip
Supported device ID and product strings:
. VID_067B&PID_2303 for "Prolific USB-to-Serial Comm Port"
Release Notes:
PL2303 Driver Installer v1.1.0
Changes from Installer v1.0.6.26:
Driver Changes (no change from last installer) -
- Windows 98/ME Driver: v2.0.0.19
- Windows 2000/XP/Server2003 (32 & 64-bit) WDM WHQL Driver: v2.0.13.130
- Windows Vista/7/Server2008 (32 & 64-bit) WDF WHQL Driver: v3.3.10.140
Installer Changes -
- Fixed cannot run installer program in Windows 2000 SP4.
- Change version numbering format based on Installshield 3-digit format.
Installer & Build date: 1.1.0 (2009-12-02)
Language Support:
- English (default)
- Chinese (Traditional)
- Chinese (Simplified)
- Japanese
Prolific Technology Inc.
http://www.prolific.com.tw
ive read to use it with megajolt it needs the p2303 chipset which it looks like it has and works with windows 7 so hopefully it will work with megajolt
installed the drivers and its finding it under com port 3 so looks like its working with windows 7 64bit
