Bad EDIS unit???
Posted: Fri Sep 30, 2011 11:55 pm
My V3 MJLJ was working perfectly. I wanted to change my tables and upon connecting it to my laptop, I noticed I wasn't getting an RPM signal (MAP works and I can upload/download). Measuring pin 1 on EDIS not running gives a little over 12 V and I get 6.93 V when running...same for PIP input on MJLJ. Pin 3 on EDIS unit gives .01 VAC (same on SAW output on MJLJ). Disconnected PIP and SAW from MJLJ and engine runs the same. Tried switching VR leads, used a different serial cable, and hooked it up to a MegaSquirt box that I know works....still no RPM. Advance in software stays at 10 deg and the timing tape on my balancer doesn't budge when I increase RPM so I'm assuming it's in limp mode (although it runs remarkably well). Which pin on the DB-9 carries the RPM signal to the laptop? Any suggestions or troubleshooting tips would be appreciated.
