Testing EDIS Module
Posted: Tue Nov 15, 2011 10:31 am
by boldy205
Morning! I had a look through but couldnt find the answer. Is there a way of testing the EDIS 4 unit with a multimeter, oh and also the coilpack please?
Many thanks!
Matt
Posted: Thu Nov 17, 2011 6:24 am
You can check voltages and signals of the EDIS module when powered up on the motor.
See the verification steps here:
http://www.autosportlabs.net/MJLJ_V4_ve ... tion_Steps
For testing the coil, the primaries should measure about 0.6 ohms, secondaries should measure about 15K ohms.
EDIS testing
Posted: Thu Nov 17, 2011 8:52 pm
by boldy205
Thanks Brent, i presume the tests for the coil are between coil live (feed) and battery/body ground for primaries. Do you measure the secondaries between the coil H/T output and battery ground?
Thanks for the info.
Matt
Posted: Fri Nov 18, 2011 7:37 am
On a 4 post coil you would test the primary windings between the center pin and one of the outer pins (there are two coils inside this coil pack). Channel A is left side <-> middle ; channel B is right side <-> middle.
For testing the secondary windings you would probe between the two posts on the left (with the connector facing you) for channel A, and the two posts on the right for channel B.
Posted: Tue Nov 29, 2011 12:00 pm
by spandit
Does the 4-post coilpack fire two "posts" at each spark (i.e. can you interchange the ignition leads to help diagnose problems?)
Posted: Tue Nov 29, 2011 7:40 pm
by toenee
As above there are 2 coils that fire alternately, each coil has 2 leads. So everytime a coil fires, 2 plugs spark.
Posted: Tue Nov 29, 2011 7:41 pm
by spandit
Thanks again...
Posted: Tue Nov 29, 2011 7:47 pm
by toenee
No worries bud, think we've all been there.
Posted: Tue Nov 29, 2011 11:46 pm
by boldy205
Right, thanks for the replies, i have ran the tests, all components seam fine, but upon cranking i saw a blue flash, dug the wires out and found a power and tacho wire shorting on the underside of the battery tray! Wooo hooo!, gotta be it! Spent this evening digging out all wires, double checking and repairing the loom!
Hopefully its sorted by the weekend!
Thanks again
