Can I use a map for a megajolt with a map sensor on a tp one
Neil.mcp
Post by Neil.mcp »
Basically I had my 2.0 zetec set up on the rolling road using a megajolt with a map sensor I now have another megajolt but it's a tp set up can I still use my map that I have saved or is it different? If so can it be converted or am I best to get it set up again on the rollers.
Cheers Neil
Swedge
Post by Swedge »
You can convert it manually you nee to find your highest and lowest vac readings then convert them to the 0% to 100% of the tps signal
For example
Minimal vaccum 200
Max vaccum 600
So 50% tps value would be 400 vaccum
