Sensor Resources
Posted: Sat Jan 05, 2013 2:22 am
Here is the master document of integrating different sensors for every use case. This is a living document - once we have anti-spam measures in place on the wiki we will open up for public editing.
In the meantime, if you would like to contribute to this document email us at
racecapture@autosportlabs.com. Thanks!
http://www.autosportlabs.net/RaceCapturePro_Sensors
Posted: Mon Jan 06, 2014 6:32 pm
The sensor guide has received some significant updates. Check it out and let us know if we missed any sensor types!
Thanks for the updates
Posted: Wed Dec 13, 2017 1:24 pm
by murph1379
A question I've had in trying to get active sensors working... Is the 5v reference meant to be the only 5v power source for the sensor, or is that supposed to connect to a 5v power source and ensure the RCP sees 5v as the same thing as the sensor does?
An EE friend was trying to help troubleshoot and suggested I probably need to feed 5 volts to the 5v reference and to the sensor from an external source.
If that is supposed to be the only 5v power source for active sensors, can it power more than one? Like say a brake pressure sensor and a coolant temp sensor?
Posted: Wed Dec 13, 2017 4:17 pm
The 5v reference on RaceCapture/Pro and RaceCapture/Apex is a 5v output supply for sensors, provided for convenience. Naturally, you can use a different power supply for your sensors.
We have a variety of hookup guides in the wiki here that show how to connect different sensors:
https://wiki.autosportlabs.com/RaceCapturePro_Sensors
Posted: Fri Dec 15, 2017 1:22 pm
by murph1379
Thanks, do you know how many amps the 5v out can supply?
