Sharing Maps
boldy205
Sharing Maps
Post by boldy205 »
Hi, i have a map for a 306gti6 engine, standard apart from a pair of 45s.
I would like to be able to share this if needed. just like to know how to 'get' the map?
Also, my Megajolt ECU has a serial port, can i upgrade this to a USB safely without damaging my ECU/map?
Many thanks
Matt
Peugeot 205 GTi in miami Blue, started life as a Std 1.9, now track day preped and fitted with 306 GTi6 engine, Twin 45s and MJLJ. Ba da da da da, IM LOVIN IT!!!!
Hi Boldy205,
You can save the ignition map using the Megajolt configuration software, connected to your PC using a serial cable. Full instructions can be found here:
http://www.autosportlabs.net/MJLJ_V4_Operation_Guide
