why isn't my oil temp acquisition correct?
Posted: Wed Apr 24, 2013 2:37 am
I have my oil temperature signal connected to pin 9 on the RaceCapturePro.
I'm pretty sure that pin 9 should be Channel 6 of the Analog inputs.
Signal mapping is setup like pictured.
I read approximately 1.22V at pin 9 where the signal is connected. This is approximately 190degF.
So why does the logfile and the Runtime show 1125895796?
I have the wideband O2 connected to pin 8, which should be Analog Channel 7 and it reads correctly, except for the incorrect precision which I previously reported.
So why doesn't my oil temp signal calculate correctly?
