can i use the ford EDIS and Megajolt with the OEM 4age ECU?
or do i have to use megasquirt? i have everything hooked up
but getting no spark. i dont have the tack output on the EDIS or Megajolt hooked up to anything. do i need this hooked up to run.can someone help. Thanks, Scott
Megajolt + EDIS with 4age ECU
Yes. For example, I'm using
Yes. For example, I'm using Megajolt and ECC-IV. You have hoocked up megajolt improperly, that's why you can't start.
Stock ford hook up: ECU takes SAW signal from EDIS and gives EDIS a PIP signal.
What you did: You cut SAW signal to ECU and feed it to megajolt.
What you need to do: Provide SAW signal to both ECU and megajolt.
ECU uses SAW for fuel injection. Click EDIS Information link on top of page.
AL
AL
No. Use your current ECU, ju
No. Use your current ECU, just provide a SAW signal to it.
saw to what pin out
what pin out would the saw go to on the 4age ECU??
