Log voltage off of Pin2?
Posted: Mon Jun 10, 2013 8:01 pm
by sbarton
Is it possible to have the system log voltage and just use pin2, since that is hooked up to the power source anyway?
-Scott
Posted: Wed Jun 12, 2013 8:01 pm
Hi Scott,
Analog channel #8 is internal and not connected to the terminal block and is hard-connected to measure system battery voltage, if I understand what you're referring to.
Just set a sample rate and select the channel name "Battery" and you're good to go.
Posted: Wed Jun 12, 2013 10:37 pm
by sbarton
Do I need to hook a wire to analog 8 to do that?
Posted: Wed Jun 12, 2013 10:47 pm
Nope! As before, it's internally wired and not hooked up to the terminal block. You get it automatically.
