Brake pressure sensors
Posted: Wed Oct 16, 2013 6:51 pm
by Hutchie
Has anyone found a cost effective brake pressure sensor to use?
i'd like to analyse where I'm hitting the brakes and how hard. I can find hydraulic switches (on/off) for brake lights but the proper pressure sensors for this kind of application seem to be about £150 in the UK - a bit more than I want to spend (all right, a lot more!)
I have seen second hand ABS brake pressure sensors for various vehicles ranging from £15 - £50, I did ask the question of one of them regarding pin outs etc and was just told it has three pins - not much help!
Ay ideas/advice much appreciated.
Posted: Fri Nov 15, 2013 1:33 pm
by smig
Posted: Fri Nov 15, 2013 2:01 pm
by ohiokm11
Looks like a great find! Thanks!
Posted: Fri Nov 15, 2013 3:00 pm
by neoraptor
You can also look to the DSC sensor from BMW. I had mine for 30€ (0-250bars).
Posted: Fri Nov 15, 2013 7:02 pm
by Hutchie
Agreed these look really great!
I did buy a used Merc sensor (used on the A class ABS) but I haven't got any pin out info so will play around but may scrap that idea!
Many thanks Guys
Posted: Fri Nov 15, 2013 7:57 pm
by smig
As best I an tell these are a drop in replacement for the Autometer 2240 pressure senders. They definitely have the same 3 pin connectors and pinouts. I have the 0-100psi versions (equivalent to Autometer 2246) in use at the moment to monitor fuel and oil pressures.
One of my winter projects is to hook up 2 of these to monitor front and rear brake pressures.
Posted: Fri May 09, 2014 6:46 pm
by jakekooser
Those links are dead, can you repost a link, or a searchable part number?
Posted: Sun May 11, 2014 1:13 am
by smig
Posted: Sun May 11, 2014 10:57 am
by jakekooser
Posted: Wed Mar 04, 2015 2:03 pm
by jottofar
I just ordered this one. Not testing done as of yet but I think it should be fine
http://www.amazon.com/gp/product/B00RN1 ... nk20337-20
Posted: Thu Mar 05, 2015 3:39 pm
by cyotani
I have one of those as my oil pressure gauge. It seems to be working well after a month of use but I have not calibrated against a known good sensor to verify it's accuracy. You can't beat the price tho.
Posted: Mon Mar 09, 2015 2:43 pm
by jottofar
Awesome great to know. I am not sure I will be able to verify or calibrate either but I really just need to know when I hit the brake and how hard so I can compare to my co drivers so even if the data is a little off it shouldn't matter for my use.
