Using Digital Expansion Port for Analog Signals
Posted: Thu Nov 21, 2013 1:26 am
Brent (or Anyone)-
By the time I allocate 7 analog channels, there's nothing left for 4 channels to measure suspension/shock displacements. I plan to use 7 channels for wheel speed, steering angle, throttle position, brake pressure, oil temp, oil pressure, and water temp.
You hint that the Digital Expansion Port can be used to add "more analog or digital channels". Care to enlighten me how this might work?
Having read the sensor threads, it looks like either the BMW headlight position sensor or the optical proximity sensor are 2 options for measuring suspension movement.
Harvey
Harvey
