mega jolt v4 tach out to rpm input race capture pro
Posted: Mon Apr 14, 2014 8:42 pm
by azz1266
Im trying to use the signal from my v4 megajolt tach out to the rpm input of the rc pro.
I recieve a signal but its not matching the one on the megajolt config screen.
any ideas how i can get this to match? It shows the rpm 200 less the the config screen?
ta
azz
Posted: Wed Apr 16, 2014 5:00 pm
by azz1266
Anyone?
I want to avoid buying the coilx pcb as I have the feed there already from the megajolt ecu?
Ta
azz
Posted: Tue Apr 29, 2014 9:19 pm
Thank you for the response. I think you have your RCP configured correctly with the clock divider; there might be an issue with RPM calibration inside of RCP. Let us investigate and get back with you!
-Brent
Posted: Tue Apr 29, 2014 9:21 pm
by azz1266
Thanks brent,
im sure its just something silly!
Azz
Posted: Tue May 06, 2014 9:59 pm
by azz1266
I have an update for you guys.
Had a couple more goes at getting the rpm signal to work properly and I have solved the issue!
Firstly I had a dirty cable connection going into the rcp unit which made the signal intermittent.
Secondly the rpm settings are as follows,
for the correct rpm signal from a megajolt v4 tach out pin, using a 36 toothed trigger wheel on a 4 cyclinder engine the clock divider needs to be 128 and the pulse input per ignition event needs to be 2! NOT 36 as expected.
unsure why but these settings work for my 1.3 polo gt
now to crack utilising the oem temp sensors without any calibration data!
I will pop a picture up when ive finished the wiring of my install
azz
Posted: Tue May 06, 2014 10:02 pm
Thank you for the update! How close is the RPM between Megajolt and RaceCapture on your system?
Posted: Tue May 06, 2014 10:07 pm
by azz1266
Pretty close,
im going to do data logs on both tomorrow,
Is the megajolts data log set at 1hz as I tried to compare logs and I had more data points on the rcp.
what time stamp does the megajolt data log capture also, just trying to marry up the 2 of them for an easy comparison
azz
Posted: Tue May 06, 2014 10:09 pm
You can use the time column in the log file for comparison. Also, you can do a casual test by simply holding RPM and monitor both apps simultaneously
Posted: Tue May 06, 2014 10:10 pm
by azz1266
By the way When I mean pretty close, I mean they look exactly the same
azz
Posted: Tue May 06, 2014 10:14 pm
by azz1266
Ideally I want to compare both bits of data to confirm they are the same,
I know the gps records seconds from midnight but im not sure what time stamp format the megajolt software is in?
azz
Posted: Tue May 06, 2014 10:16 pm
IIRC the MJ software records current time.
Posted: Tue May 06, 2014 10:34 pm
by azz1266
mine differs from the normal time?
please see attached screen shot
azz
Posted: Tue May 06, 2014 10:42 pm
Which log file is this? Could you just attach the actual log file data instead of a screen shot?
Posted: Tue May 06, 2014 10:48 pm
by azz1266
Im not on my laptop now (on the tablet)
Will have a play with it tomorrow and attach the log file tomorrow evening.
Azz
