Kock Sensor
Posted: Thu Jun 02, 2005 11:48 pm
Hi All,
Knock sensors have been asked about before but they don't seem to have been discussed much by anyone. Anyhow I'm really keen to implement something so I can push the timing up with the knowledge some level of protection exists.
My thought at the moment is to use a standard knock sensor which when triggered cuts the signal from MegaJolt to EDIS (SAW is it, I forget which) which would (after 4 ignition events) take the timing back to a safe 10 deg BTDC. This assumes that that MegaJolt and EDIS wouldn’t mind being ‘HotSwaped/Unplugged’ during operation – comments Brent?
Main prob I see with this is that it would be after 4 ign events so the potential detonation damage would be extended a bit. Anyone have any thoughts by how much this may be – is the 4 event delay significant or not?
Obviously the only other aspect of the circuit would be 'extending' the signal from the knock sensor such that it stayed on for a length of time long enough for the driver to notice a warning light of some kind.
Any thoughts ideas comments would be good. For the sake of £5 worth of bits something like this could make tuning a lot easier as you could safely keep increasing the advance until this circuit cut in. On which note, does anyone have a good understanding of any times when the engine may develop max power at an advance significantly less than the point just prior to detonation?
Chris
Chris
