Brake pressure
Posted: Tue Jan 13, 2015 12:22 pm
by jakekooser
If you're monitoring brake system pressure on a dual-circuit master cylinder, which circuit do you use, or does it not matter? As far as I can tell, my Porsche 911 is split directly front & rear, not diagonally.
Posted: Wed Jan 14, 2015 12:52 am
by rdoherty
It depends on what you want. If you purely want to do driver coaching/learning then it doesn't matter (but probably just front as you'd get a larger spread of pressure therefore easier to detect small differences).
If you're doing car monitoring and need to know about exact brake pressures to determine problems then you'd want a sensor on both lines.
Hope that helps!
Posted: Tue Apr 11, 2017 1:17 pm
by cj9694
What size pressure gauge would need to be installed? I have no idea what kind of pressure to expect from say a Miata brake master cylinder.
